Cub Cadet CC Rider 30" advice
58farmallcub
I'm new to this forum and need some advice. In a nutshell, I have a .46 acre yard, mostly flat with a few trees and shrubs to get around, and it tales me an hour and fifteen minutes to mow the yard with a 21" mower. I also work a 60 hour week and am raising a family, so frequently get behind in my yard work because I have little time to spare. I was thinking of replacing my aging mower with a wider format model to save some time, but have found precious few choices in the category between 21 and 42 inches for the homeowner (non-commercial). I want to buy new, because I'm of the opinion than very few people properly service/maintain their lawn equipment and when you buy used you are buying other people's problems. Also I only have $1200 max to spend. So all there is in this market segment is a Toro Timemaster 30," walk-behind, or a rear engine rider (Troy-built/Craftsman/Cub Cadet CC/ 30"), which all appear to be the same machine at different price points, all made by MTD, which also have mixed reviews, just like the Toro Timemaster. I don't really want a 42" as it seems a little big for my yard and it would take up more room in my crowded garage.
So a few days ago, I purchased a "reconditioned" 2014 Toro Timemaster 30" at Home Depot for $400 off the retail price, thinking I got the deal of the century. I took it back the next day because it ran rough and took a million hard pulls to start each time. I think either the carb was leaking gas into the cylinder from lodged dirt in the float/needle or the compression release valve was stuck. Once I got it running, it cut the grass beautifully. But the engine had troubles. I took the reconditioned one back went to buy a new one, but the lawn and garden manger came up to me and said not to buy it. He said nearly all the Toro Timemasters he's sold this year have been returned for engine trouble. He said to buy one of the many riders they have online for about the same price. I'm torn because the the Toro Timemaster is perfect for my yard, but online reviews and the Homedepot Lawn & Gareden manager paint a picture of unreliability, and $1000.00 is a bit much to pay for a problem machine. I called an Atlanta are independent Toro dealer and they said they don't sell them anymore, just service them because it's not a quality brand anymore and parts are hard to come by. Should I buy the rider instead?
So what would you do if you were in my shoes? Or in my yard?
Much thanks in advance for whatever advice you can give.
motoman
farmall, First , I only own a Craftsman 48 rider. I would avoid Chinese sourced engines. They are not quite there yet. Next, after being in this forum a while I think any air cooled engine must be babied while you hold your breath. Sound like you will. I am a big proponent of monitoring heat. Though few will do it have at least an oil pressure gauge installed and watch it like a hawk. It can tell you if the engine is especially hot (5psi drop from, e.g., 40 psi) or if you are dangerously low on oil (e.g., 20 psi readout at hot ). Next keep the machine inside if possible, out of the elements. These things IMO are not ruggedized like upscale tractors. I do not know how to advise engine make. They all seem to have weakness. :smile:
Ric
If your stuck on the 30" take the step up model and go to the Toro Turf-Master 30" commercial, it will cost a little more but either The Turf-Master or the Exmark 30" can be purchased for $1699. They both run the Kawasaki FJ 180V KAI Commercial engine and would last you forever. They can cut your working time by up to 40%, you wont find them at Home Depot though, you'll have to go to a dealer. I've run The Turf-Master for two years and I love the thing and you get a three year warranty.
