wilson.campbell
Brig and Strat quantum with auto choke and primer.
Would apprec some help and advice. Cleaned carb and replace sparkplug (as faulty). Mower worked for one long cut with multiple starts. Week later started for couple of second and I turned it off to adjust height setting and now it will not start no mater what (fuel and oil levels ok). Have checked and spark plug OK (using multimetre) and there is current from the magneto (used tester that lights up). Motor does not even seem to turn over. Just pull card and magnet etc works but no ignition. Tried with out filter, tried to spray some carb cleaner into carb in case it is not priming (has auto choke and primer). Fuel is held in can so no chance of water in fuel etc. Auto choke arm sitting OK and moving correctly. Also loosened carb bolt to check if fuel in bottom and their was (let it empty). Checked again after trying start again and there was fuel in it again. I am now stuck. Any ideas.
