Engine fills with fuel
mowatty
hello everybody!
I am a newbee here with a problem. i gather that happens a lot. i have lurked on this site many times before joining. i have the app on my iPod for over two years. you all seem to be friendly and reliable.
i have a Craftsman YT3000 with the 21 hp briggs single cylinder. bought it new a little less than 2 yrs ago. installed a fuel cutoff valve right away and shut down by cutting fuel to motor. i did that a couple of days ago and heard gurgling when i went to restart. i always start with choke unless engine is still hot. this time i used choke when probably still warm and the cylinder filled with gas. it would not crank - hydraulic block, i'm guessing. rotated the cylinder and heard fuel drain--into muffler, i hope not crankcase. fuel also came out of air filter. i shut off the fuel and let sit for awhile to evaporate--over a day or two.
just went out to try starting, turn fuel on and heard gurgling--same thing. Have i got something stuck in the carb somewhere--obviously!? anybody had this happen and what's the fix. i have really terrible luck with gas mowers.
thanks and glad to be here
gfp55
There are lot of threads on that topic, use the search box and there will be an answer for you.
7394
After carb clean, make sure you drain the gas/mixed oil outta the engine & replace with new Oil & filter.. And it wouldn't even hurt to do it again after one use..
mowatty
Thanks for the links and advice. I know what I'll be doing later on. Thanks again. Let you know what I learn.
hrdman2luv
After mine filled with gas, I changed the oil. Ran it for about 10 minutes then changed it again. I let it run for about 30 minutes, and changed it again... Mine doesn't have an oil filter. So it wasn't very expensive. But none the less, even if I'd had a filter, it would've been a lot cheaper than to replace/rebuild the engine...
7394
That's better yet.. Oil is cheap compared to engines.. :thumbsup:
