Engine Cratsoman 16hp turns over slow wont fire
Hekkler
Have checked battery have reset values has new carb Im lost on what next dont have money to take to shop
i pull plug it turns over fast
i have pulled exast off to see if it was pluged
adjusted values to intake .006 exhaust .008
what else can i do
Post model number from under seat & all engine numbers.
Check engine ground cable from negative battery cable to engine crankcase, check for corrosion & being tight.
Model 917-275350 year 2003 16 hp OHV Craftsman I/C
i pulled both ground cable and hot cable cleaned both and cased both to the ends and cleaned all connections
only thing i have n't done is pull starter and have it load tested it does spin freely with plug out lol but with plug in --
sping then hit top presure and stops
any good ideas
any good ideas
CRAFTSMAN Tractor Parts | Model 917275350 | SearsPartsDirect Batteries are load tested, starters are checked on engine with machine to check starter draw. Check out wiring diagram at bottom of page, using a multimeter tool you can diagnose your problem.
any good ideas
Seems it would have to be electrical. A week starter and/or battery as Mark is talking about.
I had a battery on my Ford Bronco, that showed a full charge. But would hardly turn the motor over... New battery, and whamooo, fixed the problem.
new battery allready i had starter checked it was bad i just need money to get lol
but it has took 4 weeks to find the problem hope this is it
