Repairs HR215 K1 HMA Broken Blade Clutch Control Cable
wes
Am hoping somebody would kindly post the service manual instructions for how to replace the blade clutch control cable for this Honda HR215K1HMA
MZAM# 6252528. Thank you for your time and consideration.
Disconnect the cable from the control/levers on the handlebar. Loose/remove cable straps on the handlebar. This will give enough slack to disconnect the tip of the other end of the cable from the ball control assembly, where there is an eyelet/hole that holds tip of the cable.
