silver1
I don't want to spend $100 plus bucks for a replacement as yet. If it is part of the unit, I will just use JB weld and see what happens. It is a spare one that was on the 080202 0520 3 HP and it needed a new fuel tank. I purchased Carb. and tank together. The original tank had chunks of rust come out of it.
Still need to try and salvage it. Any good ways to do that? (other than rocks!)
Still having some problem with the newer carb. I cleaned, replaced the diaphragm and needle & seat. It starts and runs only with the chock full on and alot of throttle. It will run a long time like that, but stops if you touch anything.
Thanks for you reply.
Silver1
I put the original carb. back on after using JB Weld on the pickup. It looks real good and flows fuel as good as new.
It acts just like the other one. Starts at full chock/throttle. Could it be the points?:tongue:
