Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 15, 2014 #1 Never again will I buy a B&S anything. When a blade adapter with a built in shear pin can do this to a crank instead of shearing the pin itself it's a sad thing for the manufacturer.
Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 15, 2014 #3 exotion said: What machine was that on? Click to expand... A 175cc, 775 series Electric start Briggs and Stratton which is now junk. :thumbdown: The motor runs great I just can't put a blade on it.
Nwatson99 Well-Known Member Joined Jul 29, 2013 Messages 531 Aug 15, 2014 #4 Was it hardened key-stock in it instead of the soft to shear out?
Lawnboy18 Lawn Addict Joined Jul 14, 2013 Messages 1,451 Aug 16, 2014 #5 That is rather odd. Was this on a Cub Cadet push mower?
Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 16, 2014 #6 Nwatson99 said: Was it hardened key-stock in it instead of the soft to shear out? Click to expand... This is the blade adapter, I'm assuming it's a cast.
Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 16, 2014 #7 Lawnboy18 said: That is rather odd. Was this on a Cub Cadet push mower? Click to expand... Yes it was on a Cub but it's still a B&S engine.
OldMasterTech Member Joined May 5, 2013 Messages 33 Aug 17, 2014 #8 Ric said: Yes it was on a Cub but it's still a B&S engine. Click to expand... Ric, can you cut a keyway on the opposite side to try and get some more use out of that engine?
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,287 Aug 17, 2014 #9 Cause, blade bolt came loose.
Ric Lawn Pro Joined May 7, 2010 Messages 5,765 Aug 17, 2014 #10 Rivets said: Cause, blade bolt came loose. Click to expand... No the blade bolt did not come loose. It was secure when I removed the blade. The blade adapter turn about 1/3rd the way around the crank shearing the crank before the adapter broke.
