Best Trimmer Line?
I use MaxiEdge commercial. I buy it at Tractor Supply Company. A big spool will last me through the year.
I have been using the same thing. My local TSC only has .095 we run .105.
I am going to try the Echo line in .105. Hope they have it in this week. We are getting low.
Usually I run .095 inch line in all my trimmers but if none is in stock I'll just buy .105. Both lines work pretty good.
That MTD Arnold stuff is about as good as any and better than most around here.
Try the Oregon Magnum Gatorline with the Kevlar strand in the center. Or their newer Platinum twist, you all will love them.....
Yeah, I got a little close to my tractor plow. and it did whack off several hunks of steel!!!!!!
