Echo SRM 210
SeniorCitizen
Is there an Echo expert in the house that can tell me if the gas tank of an Echo 210 string trimmer has a slight positive pressure when running.
MowerMike
Absolutely not. The tank is vented to atmosphere through an external line with a vent. The vent may be clogged or the line may be pinched. It may be time to buy a RePower kit with replacement fuel and vent lines.
exotion
So that's where my Vise Grips are that I can't find. :laughing:
Ha! Lol all honesty the rubber grommets, fuel lines, fuel vent, and fuel filter all come in one kit and should prolly be replaced anually regardless of use. All home depot has them like $12. While your there pick up a new plug and air filter. $10 it'll run like brand new.
taylor24
I have a Echo SRM 210 SN S72812154167. It will run on full choke but as soon as I turn the choke off it dies. I have cleaned and taken apart the carb. Someone said get a rebuild kit but could not find one that matched the serial number on my trimmer. Any ideas on what kit will fit?
