Drive ways
jekjr
Do any of you guys repair drive ways? I am seriously considering buying some equipment and giving it a try.
My truck for smaller loads, have it delivered for larger loads. A landscape rake, scoop shovel, wheel barrow, my eyeball
I am thinking hard about a small tractor, front loader, box blade, possibly small dump truck.
That is a lot of money! Start small and once it kicks up get a Kubota or something of that sort with a loader and digger in the back. Then, get a trailer with dump box to haul a couple yards. What truck do you have?
The company I work with sells driveway gravel $27 a ton. For delivery its a min of $140 and I can usually get the sand and gravel in the same truck and have plenty.
I have a Dodge 2500 with a Cummins and 6 spd standard shift.
I am hunting about a 10' dump trailer or possibly a 1 Ton dump truck.
I already have some work if I can get some equipment.
I need something like a 20+hp Kubota or other tractor. Front end loader, box blade, disc, bush hog, and a seeder.
Drive ways, hunting clubs, and much other work normally available for those tractors.
