shurguywutt
- Jul 17, 2013
- Threads
- 30
- 231
What type of fuel are you using?
Is this a 10 year old murray with a newer 6.5 hp engine?
Did the overheating happen with the "old" motor on the mower?
Just from the limited information I have from your post and not being able to be onsite to troubleshoot your mower, it sounds like something in the mower portion is causing an extra load on the motor, causing it to operate beyond spec which may be causing it to overheat. I suspect this because you mentioned overheating with your old motor as well.
Have you had your blade sharpened and rebalanced lately?
