Psychlopath
- Jun 8, 2014
- Threads
- 16
- 64
Snapper 33114S:
The right hand differential cover has had a hole worn in the inboard cover by the chain and sprocket.
What had originally appeared to be a crack turned out to be something much larger after removal and inspection.
The whole assembly is waiting for a trip to the parts washer tomorrow, so I can try to compare it to the diagram on Parts Tree; but before then, maybe someone can give me some insight. The fender doesn't look to be bent, which seems like it could cause the sprocket to be out of alignment, but since I dont have anything to compare it to I can't be sure. The part of the diff cover around the sprocket is worn thin enough that I have no clue if it was bent before I got it and needs to be replaced anyhow, so maybe that'll fix it, but maybe someone here knows for sure.
Here's a picture of the cover with it's hole:
![IMG_20140713_012837[1].jpg IMG_20140713_012837[1].jpg](https://www.lawnmowerforum.com/data/attachments/20/20409-6dc8003cbe533f987fb1b01bf17a184d.jpg)
Also, anyone happen to have a measurement from a new chain over 5 or so links, so I can measure mine and see if it has stretched?
