greynold99
Hi all,
I don't have all the specs on this engine with me but last night after mowing one tank of gas with my 4 yr. old Weedeater 500 lawnmower, when I refilled it - and I didn't overfill it - When I re-started it, the gas started spewing out of the 3 vent holes in the gas tank cap. It was like a very tiny stream out of each of the holes. Quite impressive but I got to thinking if the fumes hit the hot engine or muffler, it's going to get real exciting, quickly.
Well, I shut it off immediately, to avoid a fire and after moving to a level location I restarted it and the same thing happened - just spewing gas like a fountain.
Didn't get a chance to disassemble or anything last night but I was wondering if anyone has had something similar happen to them and what would cause it to happen... Also, how to fix it?
This mower was damaged by hitting a stump earlier this Spring and once I replaced the blade and shear-pin, it's run pretty good a half-dozen times but did develop a little handle vibration that it didn't have before.
However, when I was looking over the fuel tank area, I noticed a hole in the top of the frame, near the left rear engine mount bolt. Must've damaged the frame more than I realized and might account for the extra vibration I noticed.
I think I can either repair the frame bolt-hole by reinforcing with some strap-steel or get it welded. But the gas spewing out of the cap, that's a new one on me.
Any ideas or suggestions?
Thanks,
greynold99
Thanks,
greynold99
