Engine x322 mower valve adjust
glbpab1225
What is proper way to adjust valves. Just turned 200 hrs and I think they are needing done. Gets hard to crank when hot. Engine is KAWASAKI FH661A-CS04-R E/NOFH661VB93269. 22HP DATE OF MFG 0909
I WAS WRONG ITS AN X320 JOHN DEERE WITH A KAWASAKI 22 HP CODE FH661V-CS04-R E/NO FH661VB93269. ANY HELP WOULD BE APPRECIATED
Working on the 4-stroke engine since the 60's and have 3 nitro methane burning race cars the best way to set valve (I think) is:
#1 Turn the engine over with a socket on the crank bolt in direction of running rotation.
#2 With valve cover off watch the intake valve and when it opens and just starts to close adjust the exhaust valve.
#3 Now watch the exhaust valve and when it just starts to open adjust the intake valve.
