greynold99
Hi everyone,
For the past 2 years, I've been dealing with what appears to be a fairly common problem with Cub Cadet tractors approaching 500 run hours. They run great for about an hour until the engine gets hot and then start to sputter and die - sometimes you can recover at least to the point that the engine doesn't die by disengaging the mower deck pto and gently choking it to richen the gas mix. Then if it dies, you wait an hour or two, and once it cools off - starts right up and may run an additional 45 min. to an hour before the same chain of events.
All the usual maintenance: new spark plug, coil, air filter, oil/trans fluid changes done last year. Cap has been cleaned and then left off to eliminate the vent issue - some things seemed to help but the problem still happens.
I tried removing the side cover off before mowing last night and without the added heat buildup inside the engine compartment, got 2 hours of mowing and it actually never died out but I didn't want to risk it dying in a location over the hill, where I couldn't push it back to the garage...
Someone has suggested checking the 'Pulse Port' on the fuel delivery - which I'm not familiar with and wondered if it was something someone on the forum might know how to check and if it's associated with the fuel pump?
Thanks,
greynold99
Thanks,
greynold99
