Toro Timecutter z5ooo
davis.vermont
My Toro zero turn (model 74370 SN 270007372 has one drive unit that is dying. Is there any fix for this other than a $725.00 replacement?
Welcome to LawnWorld!
We moved your thread to the Toro/Wheelhorse forum.
Hi Davis,
I have the same mower. Is it the left one? My left one seems to be weak. The hydros are the EZT that are used in almost all residential ZTR mowers. The are sealed units and are not meant to be serviced or repaired. However, if you are mechanical enough I have heard you can take these off and drain the fluid. You can also take them apart but I don't know where you find parts.
Good luck,
TLG
