earthfromspace
- Jun 10, 2014
- 8
So I know there are tons of posts on this same subject, I have read a bunch of them, gone through youtube videos on cleaning a carb. My buddy had my B&S Super Bronco Tiller for about 2 years, had left gas in it. When I finally got it back I filled up the gas tank and went out. Came home to the gas leaking out through the air filter. I had never done any carb work before so didn't know to pinch off the hose, so learning as I go. Anyway bought a carb overhaul kit, cleaned the carb good put it all back together and gas still leaking. I checked the float, didnt have liquid in it. The needle and seat was replaced, I put the seat with the grove facing into the body. float was level and made sure the seat was pushed in. it's possible the gas is not pushing the needle enough to close off the gas, not sure how to figure out if that is happening for sure. Anyway, removed and put the seat back in, the gas is obviously going into the bowl, but something is not allowing the needle to close off the flow. Not sure where to go from here, I also had changed the valve throttle, so between the kit and that it was around $26 with shipping and all. a new carb I saw for only about $58 so at some point, it might have been cheaper to simply buy a new carb, but this gives me some experience to fix things myself. I have 2 non-starting 2-cycle leaf blowers which 2-cycle I always have problems probably due to my mixing, so have had my 4-cycle blower for about 5 years now with no problem. Anyway I digress, this is all a great learning experience for me, but at this stage, maybe the float is not being pushed up enough by the gas to close off the gas flow.....any suggestions would be great.
