this engine normaly starts by pushing throttle control to top of travel (Choke position) pull back one notch when engine starts...lately it seemed to flood while cranking in choke position but it would start if the choke was opened and though it would miss and sputter it would finally clear itself also NOTE immediately at start dark moist smoke from exhaust changing to normal...  now for the bad stuff.....It started this AM (all above conditions present) and after running for about 5 min. began to really miss and emmitted heavy white smoke, (vertual clouds) then clear itself for a min.or so, then start to smoke and miss again. I shut it down, got it back to my shop, drained the oil and got about a gal. of gas and oil mix...
.I've thought about a needle valve seat problem (this system does not have a gas shut-off valve)
I'm thinking of installing a fuel shut off, adding fresh oil and trying it again..BUT..I'm wondering if by starting it again I might cause further damage if the gas in the oil pan results from some other internal problem.
learned comments or advice appreciated...thanks......CORNEY
