I just recently purchased this LB, and only used it twice.  Seemed cut very good.  HOWEVER, today when mowing the grass, smoke (lots of it) came out of the muffler, and it stopped running.  Is the piston causing the problem?  Thanks.
			This is an older Lawnboy, Model 19335, made in 2000. It is a 4 cycle, tecumseh engine LEV120. I tried starting it again hours after it stopped, and it appears very low compression. I suspect piston and ring, and fixing this over my head and may be too much expense to get a dealer to do it. Thanks.
