Old Murray
- May 24, 2014
- 10
This is my first post on here so if I have left out pertinent info I apologize ahead of time. I'll do the best I can to describe the problem and hope someone has an answer.
I have a Murray riding mower model# 425007x92. It has a Briggs motor. When I try to start the mower I get 12 volts on the pole on the battery side of my 3 pole solenoid but only 3 to 5 volts on the starter side and the same voltage (3 to 5) on the pole attached to the ignition switch. When I turn the key the starter makes a half turn and then the solenoid starts clicking. When I remove the wire to the starter and turn the key I get 12 volts on all three poles. The solenoid is brand new (two days old) and the battery is fully charged. Also, when I remove the spark plug the starter turns with no problems but the voltage is still low on the starter side pole and the ignition switch pole. Clearly, something is wrong, but I don't know what it is. My guess is the starter, but it is just that; my guess. I disassembled the starter and the brushes appeared to be in good shape and, from what I could see, the windings looked good, but I know you can't see all of the windings so that's why I'm not sold the starter is good. My other guess is the spark plug. Any ideas? If you think I should test the starter can I do that with a multi-meter and, if so, how would I go about testing it? Thanks in advance.
