wiring question
odi174
i am trying to wire a newer motor to an old dixon zt
will it be wired correct if i wire the engine wire with the diode to both the red/white wire on the engine plug and the red wire labeled " to alternator , the green wire from the engine plug to the ground wire going to the stator, and the a/c wire from the stator unattached, since i have no lights to be run...
engine model is briggs #311707 0137-e1 code 010409zd.
Thanks for any help you can offer.
Re-check engine numbers. Can't find 0137-01.
