piston hitting spark plug
Gearhead0101
I figured it out yall. Spark plug lost the compression washer allowing the plug to screw in too far. Thanks for all the help
Mike88se
Oh ****... the most obvious thing is the easiest to overlook lol.
How did it lose the washer... those are pretty much on there if you know what I mean.
Gearhead0101
yeah your tellin me haha it took four rednecks to figure it out.
FloGro
Nice lol, I think the 12yc is the same as NGK's BPR6ES, if your gunna get a new plug get that one , my engines usually run better with the BPR'S
Gearhead0101
you wouldn't happen to know of a platinum tip that cross references with the 12yc would you?
Mike88se
:thumbsup: I always feel better about using NGK.
Gearhead I like regular old NGK plugs but if you want plats go to the cross reference site or NGK and find what you need.
Spark plug cross reference
exotion
This is going my memory banks.... Compression ring hahahahaha
Gearhead0101
I'm still kinda curious as to how it lost it, but I replaced the plug with a compression ring on the new one and it purrs like a kitten. Gap stays open too :D lol
