D
		Deleted member 38187
Guest
This is on an Exmark zero turn mower.  Oil has been leaking out of the left valve cover so I ordered a new gasket and got that installed.  Still leaking.  I did not see any cracks in the cover, but can these things become warped?  Possibly due to heat from the exhaust?  I see a valve cover kit from Kohler is only $21, so maybe I should give that a try.
