Did you unscrew the main jet from the bottom of the plastic carb and clean out all the tiny holes?  (Not the needle and seat of the float) You have to remove the filter screen from the bottom to gain access.  If you are careful you can reuse the screen.  The screen is just friction fit over the bottom opening, but be sure to clean the screen with carb cleaner.  There are several holes in this jet that cannot be even seen unless you unscrew it and remove it from the carb.  It is in the center bottom of the carb, the round doughnut float sits around it.  You are not getting fuel, and the only thing it could be is a jet blockage..which you cannot clean without removing the jet tube from the carb.  I like to run a small wire thru the whole thing, including the side holes, then use aerosol carb cleaner while holding the jet in my hand and making sure the carb cleaner shoots out all the holes.  You can use a flat-blade screwdriver to unscrew the jet-tube using the slots you see on the bottom.
NOTE:  This advice is basically the same for most Lawnboy metal carbs.
