Mogadishukim
 - Feb 14, 2014
- Threads
 - 1
 - 5
I just paid for 2 new blades (B & D oem) for my mower, since I ran over a lot of 3/4 gravel a few years back and damaged the old . Needed a fresh blade to mow newly planted grass. My mower worked perfectly fine before. To change the blade, I set it on it's side, removed the blade and parts, then installed new one. Mower sat on its side overnight. Have I messed up the battery? The charger appeared to work as it changed from red to green after charging for over 4 hours.
Any ideas?
			Any ideas?
