exotion
If you start to slide you have to accelerate out of it. Catch the wheels up and drive out of it if possible. The answer is 4wheel drive zero turn if your on a slope or walkbehind or stander
Thing with 4wd mowers is the center of gravity and weight distribution.. one wheel starts slipping its going to sink so more weight will be on the slipping tire and less on the wheels you want traction to. They would need a form of posi-trac for that to work
