fuel problem
collector0591
got a kohler cv492s single cylinder that when I start it up with the choke on it shoots gas thru the muffler and pops when it's turn off
thanks
I'd start by cleaning the carb first then move on to the valves. Sounds like the carb has issues.
These Kolher engines are much more supseptible to valves out of adjustment than carb problems. Plus checking the valves first is much easier and cheaper that pulling the carb and cleaning/rebuilding.
Yep it sounds like they are stuck, or not opening properly.
it didn't fix the problem cleaning the carb. and how do you check valves adjustment and what is the clearance set on them (need to by Friday)
When I seen adjust valves on the Kohler cv engine I though they were non-adjustable. So I went to the service manual and seen I was right and wrong. It looks like that engine came both ways non-adjustable and adjustable.
Yeah, I have seen both. Same with the SmartSpark....
if they are adjustable what is the clearance on int & exh do you know
