Mike88se
- Oct 11, 2013
- Threads
- 76
- 738
Okay... 3 cans of carb cleaner not seafoam :ashamed: If it's intake, you won't need carb cleaner and I don't think it's a small vac leak. I think it would need to be a big leak to cause all that. The 4.0 is a good engine and pretty easy to work on. Lots of room under the hood. My ZJ had a self diagnostics you could run using the ignition key. Not sure if the XJs had that. But then my ZJ had a problem that didn't show in the test and took me weeks to figure out the ecu had 2 fried capacitors
Bought new ones from Radio Shack and soldered them in and never had another problem.
Have fun
Have fun
Ya I did the computer relearning ill look at the egr tom if it is vac or intake I can't find it like I said I emptied 3 cans of carb cleaner looking
