Bagging Blades HRX217
Griz
I see bagging blades listed but specify a different mower. Mine mulches fine with the factory mulching blades but generally spits out a bit of the leaves to the right side when bagging.
Honda does not offer a bag-only or single-blade option for the HRX; it has always been spec'ed to use twin-blades.
Might try changing the Clip Director to a different setting, or try adjusting the height(s) of the front and rear wheels. Both will change the suction profile, and can effect leaf collection performance.
Rather than wide open which is what I always assumed was the right way. I guess a partial opening would increase suction. Thanks. I'll give that a try.
