I recently purchased a Lawnboy 10335, and it really looks good.  It ran okay, but I put in a new ignition coil, since it had the original from 1999 when new.  After replacing coil, and new spark plug, it will not start.  It seems to be that it has low compression when I use the pull cord.
If the compression is low, what has to be replaced to bring it back up? I can fix some things on the Lawnboys, but this has stumped me.
Any advice will be appreciated very much.
