Let me add my experience with spindle bearings and housings.
I have a 2002 GH 225 with a 61" deck. My comment is that it doesn't take a whole lot of loose play between the spindle housing and the bearings to cause the bearings to go bad very quickly. I was replacing spindle bearing about every 40 hours on a couple of the spindles.
Then I wiggled the blades AFTER I replaced the bearings one time and realized there was still a lot of play. Next time I replaced the housings and presto, no more problems with bearings going out.
Two additional comments: First, in my bearing replacement incidents, I came to like the sealed bearings better. They lasted longer. Second, greasing the spindles WILL quiet the noise for a little while even if the housings do need replacing. But not for long. The grease will escape out the bottom pretty quickly.
If I were sprucing up a used Grasshopper, I would replace housings and all while I was doing the bearings, etc. (Especially with a generous offer like Larry made). It will probably save you going back under there in a short time.
