Toro Recycler carb trouble
LoCo86
Has anyone experienced trouble with their Toro Recycler running rough or went from running to not even turning over? My particular mower has the Toro ( Tecumseh ) engine and it seems that the bolt that holds the bowl on and also acts as the main jet for the carb gets the jets clogged up after every use. If any one else has this problem and has found a way to solve it please let me know.
gner
Had the same trouble with 2 different Tecumseh and ending up
putting in line filters and a fuel cutoff on each machine..........
No trouble since.
I would recommend cleaning and rebuilding the carb with a new float needle/seat. Part number 631021A. At the same time cleaning the fuel tank.
