Hello all. My brother-in-law's X360 began backfiring and died while mowing the grass. Tractor has 54 hours on the clock. It's a 2011 model bought spring of 2012. The air filter looks brand new. I removed the air filter and did not help. Engine will start and backfire and dies again within 30 seconds to a minute. I noticed when I crack the throttle to 1/2 and the choke to 1/2, the mower will rev higher and run longer but will not run any smoother. Smokes black heavily when choke is open or closed. Appears it flooding out. I thought initially the choke cable may have came off and it was choking but that is not the issue. Where do I start to TS it? The float has an electrical solenoid and I don't know how to TS it.
NEW Today. after sitting for 2 hours it starts, runs, smokes heavily still, snorts and backfires until I got it into the shed.
