Fatdaddy
You could have some bad fuel that has stopped those filters up. You could have something in the tank that is moving over the fuel outlet. You could have something else.
First thing I would do is look at the fuel and see what it looks like.
After it did it in the back yard I switched to the 2nd tank right when it did it,, Then after the hour I was on the 2nd tank when it did it.. Could it be the fuel pump????
