Towing moving without starting
gary sr
I have a grasshopper 725 front deck mower and need to load it on a trailer. my question is how or what has to be done to make it possible to push or pull it. I have finally faced the fact that it's going to take someone other than myself to find out why there's no spark. all help is greatly appreciated.:confused2:
There is a dump valve under each hydro. Use a 5/8 wrench to turn counter clockwise one revolution. This will allow each side to freewheel. Just don't forget to tighten them back up! :cool:
would that be a brass colored bolt head with a hole thru it cross ways? maybe an 1/8" hole?
I don't remember if its brass or not, but its at the bottom. Just turn it one turn and it should release the wheels. Don't take it out, just loosen it.
