Repairs toro timecutter 4200 front wheel bushing issues
sawhead
ok,so regardless of how often i grease the front bushings,they squeak like no ones business for random amounts of time while mowing...my mower only has one heavy summer of use and i am wondering if there's a replacement bushing of better quality or preferrably a replacement bearing?
i have done some searching and cannot find an answer...thanks
can anyone point me in the right direction then?
This is what I would do. First, I would remove each spindle and clean them until they are as shiny as possible. Second, clean the bushings as best you can. Third, I would use a good quality lithium grease. Apply it to the spindle before installing. After installation, pump grease into bushing until it comes out both the top and bottom. A trick I use to get this done, is to pump the grease in with the front wheels off the ground. Many times the grease will only come out the top, due to the pressure of the wheel not allowing the grease to flow down. You can also spin the spindle while pumping in the grease.
thanks rivet
