LA145 John deere mower that backfires when throttling down and/or turning off
bmwmotogreg
  • / LA145 John deere mower that backfires when throttling down and/or turning off
What causes the mower to backfire once when I turn from full throttle to low throttle? The mower has about 35 hours and runs great. I am not sure if I should be concerned and/or how how to address... Thank you!
EngineMan
There are a few factors here, lean condition is only one of them.
bmwmotogreg
Should I be concerned for the health of the mower engine? What should I look at first? Plugs looked ok to me when I checked... Is there harm to the mower each time it "pops"? Thank you in advance for your information and assistance!
EngineMan
To able you help you more, we here need to know what carb is fitted to the engine to see if any settings can be done to it, post up the make and model numbers, then give us a little time here and am sure someone will get back to you.
running a engine too lean can cause problems! engines that run too lean run hot, this isn't usually the kind of hot that you can see on your temperature gauge its mostly hot inside the cylinders and the exhaust system, when engines run too lean damage to the pistons and valves can be the result, pistons which get over heated and distort and melt and burn and basically cause lots of problems with compression and burning oil, lean conditions can also cause the exhaust valves to over heat and distort and not seal properly. A valve needs to get a good seal not only to hold compression but also to cool it self, heat is taken away from the valve while it is closed, the heat goes into the valve seat and then into the cooling system.
Serious damage from extended periods of lean running are common and sometimes are hard to spot.
Fish
Most of these troubles cropped up when the mower mfgs. brought out quieter and quieter mufflers, as the many red hot baffles in the newer mufflers would ignite the unburnt gases that collect in the muffler, and most engines now have an "afterfire" solenoid installed on the bottom
of the carb to help deal with this condition, but if your unit is "new", take it back to where you bought it, and run the problem by them, and see what they say.
