8908bistro
I have a 14.5 33 Snapper with a hydrostat drive. There is a starting sequence that you have to follow to get the mower to start. That is place the mower in park, throttle to choke, turn the key and start. My problem is that I'm having to repeat this sequence several times before the starter will kick in. Is anyone else having this problem? Is there a fix that will bypass the starting sequence? Thanks
