Tecumseh 143-346062 ............correct carburetor part number and picture.
silver1
I would like to have a part number of the carb. for this engine.
I come up with 632991. The manuals that I look up the part show a different
bowl with high speed adjustment. The one on it does not have this
type bowl. I will get a new one but I want to get the correct type.
I have a 640078A that works but the choke linkage is wrong.
TVM220-157069E.
The part number of your carb is a 632282 which supercedes to the part number that you listed in your post. there should be a number stamped into the carb, get that number and somebody will be able to determine what carb you have.
The number on the carb. is 1076J6R and that comes to Part # 632282 as you stated. I'll see which one is available for the best price.
Thank you for your help.
Lance
