Scag TurfTiger Blages disengage/engine stalls
Bamaturf
Hello,
I'm a new member with similar problem as others who have posted. 2003 SMT-61A9(deck) , STT61A-27KA(engine).
430 hrs(homeowner/farmer).
Cuts fine until fuse blows, blades disengage and motor stalls. You can turn PTO off and engines runs great. Turn PTO back on , blades spin up to seemingly full speed for about 5-10 seconds and blades die, engine stalls. It always blows the fuse in the process. Battery would loose charge overnight, also. I would charge battery enough to crank but never fully . Hoping the onboard charger would complete the charge.
It caused PTO switch to burn up, replaced PTO switch. it cut fine for one day. Fuse holder getting hot & blowing fuses. Replaced fuse holder, cut for a while and everything repeated the process(except new PTO switch is still good).
I have charged the battery and it took a full charge last night but have not tried to cut due to rain today.
If it continues to fail, what is the next thing to check.troubleshoot?
Would greatly appreciate any help, Farmers don't make enough to send lawnmowers to the shop!LOL
Regards, Bamaturf
Disconnect the clutch plug, run the machine and pull the PTO switch on. Put a voltmeter across the battery terminals when doing this. More than likely your clutch coil is shorted internally or to ground. In either case, you need a new clutch as it is drawing too much amperage. There may be other problems in the electrical system as result of overload.
Check out the attachment for clutch troubleshooting.
Does your TT have an ammeter, and if so what did it indicate?
Mad Mackie in CT
Mad Mackie in CT
Thank You MM!
Its a bad clutch! Can't get clutch off, however. The main nut on the clutch sins the shaft (both ways) and I have not figured a way to hold the shaft in place while turning the nut.
Any Ideas??? I am very thankful for any advice!
Bamaturf
I use an air impact wrench.
You may have to hold the flywheel nut with a socket and breaker bar to stop the engine from spinning, the debris screen over the flywheel will have to be removed to do this. This is best done with a second person holding the flywheel nut.
