jpalladino
Last week I mowed my lawn. The Z425 ran fine. I put it away. I filled it with premium fuel and added Marvel Mystery oil to the fuel tank-2oz. like I normally do. I filled it above the fill line so I dont have to stop 3/4 way thru mowing my yard. I do this frequently except at the end of the season. When I put it to bed for the winter I run stabilizer, STP gas treatment, and MMO thru the gas/carb and run it till empty. Yesterday I went to start the machine, turned the key, it got power- the hrs showed on the meter, then turned the key and got a click. The battery was 3 yrs old. It showed 12.67amps but when a load was put on it, it dropped down to around 10 so I replaced the battery with a new one that puts out 350cca. I put in the new battery after making sure it was fully charged, turned the key, choke was on, and the motor was hard to start. I cranked it several times for 5 sec each then it finally started. It ran for about 10 sec., out came a lot of smoke and about 1/2 oz of fuel blew out from some where. I checked the oil, its full. I let it set for 5 min and restarted it. Same thing happened. The paper air filter is dirty so I am replacing it along with the top air filter, fuel filter and spark plugs-the plugs were dirty with carbon and fuel. I thought using the gas additives would help keep everything clean, am I wrong? Did I damage anything and could the new battery be producing to many cca that could damage my electrical system. Thanks for any help.
