G gwedster Forum Newbie Jul 7, 2013 #1 p.t.o. making rubbing / ticking noise is it bad ? , or just needs to be adjusted ? :confused2:
BBO Well-Known Member Jul 8, 2013 #2 gwedster said: p.t.o. making rubbing / ticking noise is it bad ? , or just needs to be adjusted ? Click to expand... It does have and air gap adjustment, but I suspect you have other problems. Attachments LX188_PTO_Test_452-453.pdf LX188_PTO_Test_452-453.pdf 464.8 KB · Views: 54 LX188_PTO_Clutch_Adjustment_457.pdf LX188_PTO_Clutch_Adjustment_457.pdf 93.8 KB · Views: 45
