what belt will go first
5speed
What belt will go first, and should i replace the mower and drive belts together ,or will one last much longer than the other
This is on a 2004 with the 20hp motor, 42in cut
Thanks
Everything is good working order, the deck belt should last 2-3 years and the drive belt 4-6 years.
impalass
Buy a kevlar belt which will last longer than a regular belt
Bomba
What is the difference between mower belt and a drive belt?
Bomba
one drives the deck [blades] , the other drives the tractor,
5speed, much appreciated. I gotta look up a diagram of this stuff and how it works.
