scalestick
Trying to determine the type of grease required for my self propelled unit .The unit skips when in second gear took it apart all well inside found the level on the outside is to loose made a new one (steel).The Honda dealer tells me I need Hydrostatic oil but the unit is full off grease(gear drive).Also the cable is at is very end any suggestion is appreciated.
Thanks
Scalestick
Thanks
Scalestick
