kingkongva
my toro has been wonderful for yrs. recently got a problem starting. i cleaned out carb, bowl, and clean sthe jet hole on the bolt that secure the bowl. the mower will start only when i prime the bulb at least 20 times. it runs fine after starting. the priming bulb look fine. i have had the chance to replace it yet. my carb look like this one below
Disassembly, Cleaning and Repair of Tecumseh Series 11 Carburetor
not sure whether i will need to use the carb rebuilt kit. but for sure i will replace the bulb first and try it and c if it will work. any tips or tricks to this problem..thx in advance
