[email protected]
This is a new problem. Craftsman 18.5 HP Briggs, 42 Inch mower with Electric clutch. Model 917.2736403
Shredded the blade drive belt. Installed new belt (the hard way) by dropping the deck. Idler pulleys were loose and floppy. The idler on the discharge side has a tension spring and seems ok, but I am not sure of the other one. The pulley was pretty loose and required tightening. It is mounted on a bracket is installed with another bolt that allows it's position to be moved. I am not sure what the correct position of the bracket is. I find nothing in the book about adjusting belt tension. The diagrams are not much help. Thanks in advance for any suggestions.
