Trouble with Briggs Quantum Air Filter Gaskets
shillnav
Is it just me or are others having a hard time getting these air filter gaskets to seal in order for the primer bulb to push the fuel. The one I've got right now is 123k02 0541-e1, but these gaskets are on many engines and I'm having problems with them.
I remember years ago they used to be made of flimsy rubber and were a real pain. When they started making them of regular gasket material I thought it was a great move. Not so sure now.
I've tried using 2, tried different methods of tightening the 3 screws that hold the air filter housing on, I've tried everything............ Is there a secret to this that I'm missing??
Thanks Much !!
Normally the double gasket will fix it. there isn't any sealant of any kind on the gaskets, that could be blocking a passage is there. Maybe a primer bulb problem. Possible the bowl nut on carb clogged preventing fuel from getting push up.
shillnav
Nope............ I can hold the air filter holder up, hold the gasket on, push the primer bulb with my hand and feel air coming out. I've pushed on the bottom of the AF holder to seal it better while attached to the carb and get a small amount of fuel coming out when I push the primer..................... I also took a small amount of air and ran thru the primer hole on the carb and get fuel coming up.................It's just not sealing well......... I checked and these gaskets were made by Rotary and not Briggs............. And this is not the first time this year that I've had this problem....... What do you think?? Thanks Ilengine
shillnav
Carb has been cleaned thouroughly
Ifixdit
As stated above, the double gasket method usually does the trick. You definitely have the right gasket with the small hole on the right side as you place it on the air cleaner cover, correct? Maybe your cover is warped or disfigured and won't seal properly.
shillnav
Yep, got the right gasket......... Going to try it again. I may be wrong but I think those air filter housings used to be a little thicker and more heavy duty. Not sure about that but I never had this problem years ago.
briggs
i have seen this 100 times sometimes the plastic will wear and it will not seal ..I have had to change the housing its self it will flatten out the top edge not allot but enough to stop it from sealing ...Also take compressed air and blow it threw the little holes in the front of the carb to make sure there clear that is part of your priming system also ...Good luck let us know hoe u make out
mistermowerman
Thanks Much !!
Hello , something else to try , check the condition of your carb bowl sealing ring ,if it has been damaged or cut , as far as i can see as you push the primer you pressurise the bowl which then pushes fuel up into the inlet . Gary:smile:
briggs
if i can find one of the old ones i have here that is worn out i will post a pic of a good plastic housing and a bad one ...they can be a pain in the back side
shillnav
Well, I got it.......... Evidently I was tightening the screws too tight. I used some loc-tite on the screws, tightened them in until I could see fuel coming up when priming. It took very little tightening of the screws to make it prime. Learn something new every day..............
Thanks Much for all the replies and the help.
Steve
