I have a Troy Built Pressure washer with a Briggs and Stratton 675 series motor on it. It has been leaking oil for a while now. It doesn't leak a lot at all, but enough to get a few drips on the driveway each time I use it. I am not 100% sure where the source of the leak is coming from but it appears to be coming from the front of the motor, where the spark plug is the part that has the fins, from the bottom of that (Sorry I have no idea what it is called). This is where I see the most oil on the outside, but there is oil however on other parts of the motor.
I was however wanting to degrease and totally clean the outside of the motor so I could be certain where it is coming from but I had a question. What is the best way to clean degrease the outside of the motor? Is it OK to spray down the motor with simple green, let it sit a few minutes then use the pressure washer to pressure wash the entire motor? Anything I should watch out for when doing this? Any better way?
Thanks!
Jonathan
Thanks!
Jonathan
