Replacing drive belt on TB210 Walk behind
drive1
Is there an easy way to remove the front belt cover on this mower, I need to replace belt. I have removed the bottom cover and the two screws under the deck but I'm not sure what else needs to be removed to finish the job. All the owners manual says is take it in to their servive crnter/
Cheers
Paul
Cheers
Paul
You can Google Troy Bilt 210 and find an illustrated parts listing, which should also be in the owner's manual. It looks like there are two screws that hold the cover in place. To replace the belt you'll need to remove the blade and any other cover underneath that shields the engine pulley on the crankshaft. Good luck!!
