Ric
 - May 7, 2010
- Threads
 - 139
 - 5,765
Thanks for all the replies...
exotion what model is your echo?
And Rick do you have a certain place that you buy parts for your Stihl's? Your dealer? I'm kind of leaning toward the Echo right now, mostly because I don't want to take my trimmer places to do maintenance, and I don't even see a parts section on the Stihl website.
A_tank96
The Spark Plug Is a NGK-BPMR7A Replace it. Looking from the Back of the engine on the right side is the muffler, if you look inside you will see the spark arrestor, Take a 15mm socket and remove it, it will be tight so you may have to give it a little tap to loosen it. it just unscrews take it out use a wire brush and clean the screen and blow it out, make sure it's clean and re-install it back in the muffler and I bet you find your machine will work great. I just did the whole process I described and it took less than five minutes, and make sure you clean or replace the air filter.
